Home > General > Height
robbo
Italy 2006 Range Rover Sport TDV6 HSE Java Black
Height
Hi to everybody
I have a problem with my garage, I wanted to know how much the car is tall to put her/it in garage, my garage it measures in height 179 cms 70,45 thumbs.
I asked if someone gives me the exact measures is in normal height that in all low.
Thanks
Post #11331 Wed Jan 25 2006 9:41am
grommet
United States
RRS's maximum height is ~181.7 cm -- if the vehicle is placed in "access height", it's ~176.7 cm.
Post #11332 Wed Jan 25 2006 9:59am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Don't forget it can be locked into access height too for going ito your garage so you need not worry about it hitting the ceiling.
Sounds like it will fit OK. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #11333 Wed Jan 25 2006 10:04am
robbo
Thanks, but when I start the car and do I move me to go out slowly it automatically gets up or is he/she low?
Thanks
Post #11339 Wed Jan 25 2006 10:25am
RRUK
When it is locked in access mode it will not automatically rise as you drive out of your garage. You can also drive down the road in locked access mode and it will only rise up automatically when you reach a acertain speed, about 20mph. L319 D4 HSE
1982 Series 3 SWB
Post #11348 Wed Jan 25 2006 10:37am
robbo
Thank's Very Happy
Post #11349 Wed Jan 25 2006 10:46am
Even when it is in access mode ( but not locked in ) it will still not rise to normal ride height untill the car has reached/exceeded 6mph
Post #11360 Wed Jan 25 2006 11:46am
The only problem is if you can only access the garage when the car is lowered there will be that time when the wife forgets to lower the suspension! Crying or Very sad 2005 Zambezi TDV6 - Gone but not forgotten
Post #11369 Wed Jan 25 2006 12:47pm
robbo
His wife drives a Mini Cooper, we hope remains there...... Rolling Eyes
Post #11373 Wed Jan 25 2006 2:07pm
Very Happy Very Happy 2005 Zambezi TDV6 - Gone but not forgotten
Post #11375 Wed Jan 25 2006 2:08pm
shlomole
France
This is an old topic, but I absolutely need to solve the same problem as Robbo's. My garage's entry is 178 mm high. I've been reading all kinds of technical specs about the RRS for a couple of weeks. The problem is that I read several heights in access mode :
- 173 cm
- 176 cm
- 178 cm
- 181 cm
Land Rover France says 1734 mm for the 2010 RRS. I read 1767 mm inside this thread. Did the access mode height change over the years ? Buying a RSS, going back home and seeing it doesn't get into my garage, would be awful Big Cry
Thanks
Post #250603 Tue Jan 19 2010 1:57pm
Tim in Scotland
according to 2010MY sales literature the height in normal mode is 1789mm with sunroof closed and roof pod, in access mode (which can be locked down) height is quoted as 50mm less at 1739mm you should also check how WIDE your garage doors are because RRS is a wide car, although not as porky as D4 or Frelander2, at 2158mm with mirrors unfolded or 2004mm with them folded in. My garage door is (just) high enough but the opening is 2014mm wide therefore not enough wiggle room so it has to sit outside. Inside my garage is 3000m wide but I am not getting the door widened to fit! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #250621 Tue Jan 19 2010 2:46pm
Endjin
Scotland
Sorry to state the obvious, but aren't all the clearance measurments displayed on a diagram printed
on to the drivers sun visor in every car? Confused 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #250630 Tue Jan 19 2010 3:10pm
Tim in Scotland
Yes, but he hasn't got an RRS yet! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #250631 Tue Jan 19 2010 3:12pm
shlomole
France
I think the width won't be a problem : a Renault Espace IV (2104 mm with mirors unfolded) fits in my garage.
@Endjin : I have never seen that, in any French car. In yours, do you read the height in access mode ?
Post #250633 Tue Jan 19 2010 3:18pm
