Home > My Range Rover Sport > Biggles - 2.7 TDV6 |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Have bought,
Fri Jul 22 2005 12:35pm |
nickp Member Since: 27 May 2005 Location: Leicestershire Posts: 111 |
Hi Biggles
Fri Jul 22 2005 4:08pm |
Not seen any of these suspension messages, but have seen today the red handbrake light staying on after removing the ignition key for about twenty seconds.
Fri Jul 22 2005 4:40pm |
I also get the handbrake light which seems to be normal and the low power mode is designed so the volume wont go so high I think when the car is not running. If you get a chance play around with the suspension from access to off road a couple of times and see if you get the warnings. |
Fri Jul 22 2005 4:43pm |
Nick,
Sat Jul 23 2005 7:37am |
Biggles
Sat Jul 23 2005 8:01am |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 |
Hi
Sat Jul 23 2005 8:08am |
Hi NeilR
Mon Jul 25 2005 1:44pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
"Suspension raising slowly" is not a fault exactly. It just means the air tank doesn't have enough saved and the air compressor is used to assist. Many people don't even notice... (same on Disco 3/LR3) |
Mon Jul 25 2005 4:24pm |
New Accessories Fitted,
Sat Jul 30 2005 12:38pm |
My first pic posted ( she has just been washed after a week getting dirty)
Sun Jul 31 2005 11:23pm |
BN Member Since: 10 Jul 2005 Location: Northamptonshire Posts: 58 |
Biggles, take a look at the string I started http://www.disco3.co.uk/forum/viewtopic.php?t=798
Mon Aug 01 2005 7:16am |
Have just added the supercharged grille side vents and also the front and rear black Landrover badges.
Thu Sep 15 2005 9:43am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 |
BIggles, how easy are the mud flaps to fit? They look simple from the instructons online, is that the case? L319 D4 HSE
Thu Sep 15 2005 1:47pm |
