Home > Technical > TICKING/TAPPING ENGINE NOISE AT COLD START UP |
pokerplayer Member Since: 30 Sep 2005 Location: Los Angeles Posts: 32 |
Your car is fine JC WAT UP WAT UP???? N6MDZ |
Thu May 10 2007 5:34am |
geezo Member Since: 06 Nov 2006 Location: cardiff Posts: 14 |
TICK TOCK.....Had the same concerns myself but apparently all is well RRS HSE 06
Thu May 10 2007 3:55pm |
CASANOVA Member Since: 05 May 2007 Location: SOCAL- SFV Posts: 19 |
WAT UP, WAT UP MIKE! .
Sat May 12 2007 6:24am |
Just a follow up. I am schedule to take my RRS to the dealer to check the tapping noise. I will keep you posted. One dealer said they cannot hear it (I am not sure if they are paying attention to the noise). I need a second opinion. "DESTINY IS NOT A MATTER OF CHANCE ITS A MATTER OF CHOICE" |
Wed May 23 2007 4:56am |
Dealers are known for having very poor hearing.... don't let them fob you off.
Wed May 23 2007 9:00am |
After two dealership and three diagnostics, they found the problem! It's the VALVE LIFTERS! Now, the question is does an AJ-V8 Jaguar engine have valve lifters when it says DOHC? Where is it located?
Fri Jun 29 2007 7:21am |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
Look at your picture where you see the valve spring. Up above you see a cylinder shape with a slot in it and the one on the left has a small hole (oil feed hole). These are Hydraulic Camshaft Followers. (valve lifters) They take up the tappet clearence between the valve and the camshaft by being fed with hydraulic oil pressure from the sump. Look at the one on the right and you see a slot on the right going to the slot on the valve lifter, then look on the left and you see the small hole where the oil enters the valve lifter via the slot in the cylinder head. When the engine is switched off and standing over night the oil can tend to drain back to the sump overnight. When you start the vehicle up next morning it takes a few seconds to get the oil pressure up there and then fill the followers full of oil. The ticking noise is the clearence between the valve and camshaft before the full oil pressure arrives. It will have none return valves etc in the engine to reduce the fall back flow of the oil into the sump when the engine stops. The whole thing is relevant to different temperatures and climates obviously because of the thickness of the oil, - hotter operating temp the thinner the oil gets.
Fri Jun 29 2007 7:56am |
Nutty N, thank you for the information and it helps, I appreciate it.
Fri Jun 29 2007 9:16am |
No C you only have to take the camshafts off the top to do it, you dont split the head gasket. You just need to hope they get the valve timing right when they re-assemble it - that is all that can go wrong really. The reason for the design is putting the camshaft directly over the valve is quick and simple engineering compared to using rocker shafts etc. Then you only get 2 efficient ways of controlling the valve clearences - you put a solid bucket over the top of the valve with a shim on top which has to be adjusted through the service life of the engine with alternative sizes of shims, (extra time and srevice costs to the customer)or the second way which you have and control it with hydraulic camshaft followers. - (No maintenance and it will normally lasts the warranty period without trouble, then your on your own) The only thing you need to know is CHANGE THE OIL TWICE AS OFTEN AS LR RECOMMEND, because once the dirt and sludge get into the follower you can't get it out. This will keep the camshafts and followers in good working order
Fri Jun 29 2007 10:07am |
Got it Nutty N, thanks a lot I appreciate. That really brightens up the day. Lets just hope they don't screw up anything else "DESTINY IS NOT A MATTER OF CHANCE ITS A MATTER OF CHOICE" |
Fri Jun 29 2007 2:13pm |
Here is the update. After 21 days in the shop, new valve job and tappet replacement, the tapping noise had disappeared. However, another issue has risen, on warm up coming down from high rpm start up, the engine vibrates and then settles. The never ending issue of my RRS continues. Oh boy... "DESTINY IS NOT A MATTER OF CHANCE ITS A MATTER OF CHOICE" |
Sat Jul 14 2007 4:36am |
canaryman Member Since: 16 Feb 2006 Location: Haag a.d amper Posts: 188 |
I had a ticking noise on my TD V6 when it was cold. Foot on brake, shift to drive or reverse with foot still on brake and the noise was quite loud (Loud, rhythmic, metallic noise coming from the front right side of the engine). Lasted about 2 minutes whilst driving and the noise accelerated and decelerated according to the car speed.
Fri Jun 27 2008 10:06am |
Occasionally you get a pulley that has a hairline crack in the middle section. Then you will get the ticking all the time - its like a cracking noise. As you say the toothed belt design helps amplify the noise. You don't stop playing because you get old, You get old because you stop playing.
Fri Jun 27 2008 8:44pm |
Danp Member Since: 09 Nov 2024 Location: Devon Posts: 1 |
Hey guys, This is a great write up but I just want to check if my problem seems similar but could be different. I have 2011 rrs 3.0 diesel auto and it was ticking intermittently on cold starts just for a few seconds, then it progressed to every time and then the last time the engine started to rumble so I switched off. I understood this to be the oil pump failing and then the crank bearings being damaged. Could you recommend a check I can do? I have since bought a replacement (same everything) and it does the tick rarely Many thanks in advance |
Sat Nov 09 2024 2:50pm |
