Home > Technical > Low coolant level..
kam100
Low coolant level..
Hi Guys.
Drove to watford yesterday and managed a very good run, no traffic hardly at all. Cruised most the way and when i let her go i occassionally got a message saying Low coolant level, then it dissapearing leaving a little i on the display.. But then it turns off and pops back every now and then.
When driving on the roads as normal this morning, no message appears..
Will top this up though asap, but need to find out what this is first?
Engine wasn't heating up or running oddly yesterday, in fact it was running very smoothly.. Odd..
Post #10712 Wed Jan 18 2006 11:55am
Pelyma
I believe this can be the specific gravity of the coolant or the header tank. Look on the other site and search it is a well known issue.
Post #10717 Wed Jan 18 2006 1:07pm
pokerplayer
Coolant level issue
Hi there Kam,
Same here, I got the low coolant error message yesterday once and topped her off last night and it showed again just a few minutes ago when I got to work. Hmmm, I didn't have a chance to check the level again but I will check it again later. Sad
Please let us know what you find out. I will do the same.
Pokerplayer Smile
Mike
Post #10732 Wed Jan 18 2006 6:05pm
Martin
Site Administrator & Owner
Sounds like the "common" issue with the D3 Like this site? Buy some RRSPORT goodies to show your support!
Post #10733 Wed Jan 18 2006 6:15pm
bgreig
United States
bad sensor
Dealer said bad sensor on mine causes it. Thanks,
BGreig
Post #10750 Thu Jan 19 2006 3:10am
maddie
Had the same with my RRS V8 changed the expansion tank £40 for the tank took about 1-1/2 hours sorted the problem. JEFF GALE
Post #363307 Thu Nov 15 2012 4:57pm
Bodsy
Site Sponsor
The float becomes porous and absorbs water. It may be intermittent to start with as it is still mostly floating. It will probably get worse unless it is an actual water level issue leaking elsewhere. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #363308 Thu Nov 15 2012 5:02pm
