![]() | Home > Technical > Low coolant level.. |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
Hi Guys.
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
I believe this can be the specific gravity of the coolant or the header tank. Look on the other site and search it is a well known issue. |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Sounds like the "common" issue with the D3 Like this site? Buy some RRSPORT goodies to show your support! |
bgreig Member Since: 10 Jun 2005 Posts: 12 ![]() ![]() |
Dealer said bad sensor on mine causes it. Thanks,
maddie Member Since: 10 Jan 2011 Location: HERTFORDSHIRE Posts: 6 ![]() ![]() ![]() |
Had the same with my RRS V8 changed the expansion tank £40 for the tank took about 1-1/2 hours sorted the problem. JEFF GALE |
The float becomes porous and absorbs water. It may be intermittent to start with as it is still mostly floating. It will probably get worse unless it is an actual water level issue leaking elsewhere. Bodsys Brake Bible
