![]() | Home > Technical > TURBOCHIP TDV8 SPORT |
tasmod Member Since: 07 Aug 2005 Location: NE Lincs Posts: 396 ![]() ![]() ![]() |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
Thanks for the response Tasmod, I have noted your own input on chipping when appropriate. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 ![]() ![]() ![]() |
Tasmod |
bkehoe Member Since: 26 Feb 2006 Location: Wexford Posts: 35 ![]() ![]() |
Certainly a reason to consider changing from a D3 ![]() |
MPG is not yet known for any distance. Original figure was 23.4mpg on the meter. I will ask him later what the change in MPG works out to.
Tasmod. |
Yes, thanks Tasmod - very informative. |
Rooleeds Member Since: 26 Sep 2006 Location: U.K. Posts: 43 ![]() ![]() ![]() |
So, can someone tell me, for chipping a TDV8 at Turbochip, is this only available as a download or can you have a "plug in box" type one, so you can remove it before it goes in for a service, etc!
Turbo chip is straight in the ECU no external boxes |
