![]() | Home > General > driveshaft vibration |
autolines - what model do you have? 2005 Zambezi TDV6 - Gone but not forgotten
autolines Member Since: 01 Dec 2006 Location: blackpool Posts: 21 ![]() ![]() |
I have the tdv6 se 2005 55. |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
If you look up transmission noise in Tech- Canaryman had problems with his vehicle
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Ohhhh yes, big time and here are some forums you should check out. I am the king of vibrations, had them all...steering, transmission and raspy chain....they all have different sources and reasons. Mine is also a 2005 RRS. Start with http://www.rrsport.co.uk/forum/topic1995.html - this covers the steering vibrations, although there is a little confusion on the the two types of steering vibrations. One is a shimmy (wheel balance / steering rack issue) and the other is the dreaded "wha, wha, wha" and graunch through the steering wheel which I think is what you are suffering and what I had. Check page 3 of the above post for my post clarifying the two. Then take a look at http://www.rrsport.co.uk/forum/topic4200.html which covers off all the bits that have been replaced on my car to sort out the driveline vibrations, including torque convertor (which was not the cause btw) Basically; 1) My driveline vibration was largely due to a worn out spider gear and bearing in front diff. To find this out they replaced torque convertor, prop shafts, tyres, transmission, hubs. 2) The rasping in the auto transmission is a problem within the transmission which canaryman has doggedly pursued and is covered in http://www.rrsport.co.uk/forum/topic2725.html 3) Finally, the steering shimmy. This is covered in several posts and is due to flat spots on tyres and overly senstive steering rack. There is a tech note out on this which involves balancing on the Hunter Road Force Machine and if not succesful, steering rack replacement with a new damped steering rack. Hope this helps. Happy to PM you any details on my car which may help your stealers and save you some time. RRS TDV6 Bluetooth, VR, Roof ![]() |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Check your paint / body for marks when you collect it mate |
many thanks to all who replied, some very useful remarks here.
