Home > General > Serious or not?
YY
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
Serious or not?
Not sure if any of you of experienced this problem.. I was driving 30mph when I get a fault "bell" and the screen says suspension fault vehicle lean when cornering, the sat nav and radio shut down, indicators don't work.
I parked on the side and turned the car off, and then turned the key but nothing would happen, no engine noise at all.. LR assistance guy came by and spent an hour on it but could not get the car started and his laptop could not connect with the car for some reason. So no diagnosis was possible. A truck came by to take it to the dealers.
Is this serious or not? The car is a Sep 2005 (55) SC with 5000 miles only.
Post #102701 Mon Apr 16 2007 8:45pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Sounds like a battery or power supply issue. Low battery output can send "ghost" messages. TB would be the man to ask. Doesn't sound major though and it's under warranty so dont worry! Good Luck! Thumbs Up MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #102702 Mon Apr 16 2007 8:49pm
Tim in Scotland
Sounds pretty serious if Land Rover assist cannot get it to do anything at the roadside.......... these guys are usually pretty good at getting you going again when the electronics play up. I wonder if because of it's age and exceptionally low mileage it hasn't had the various electronic upgrades done at service time - are you the first owner of the car? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #102703 Mon Apr 16 2007 8:51pm
The doc
I've had simillar problems...
Post #102707 Mon Apr 16 2007 9:15pm
Brian Mason
Go on then Doc.., dont be a tease! Whistle MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #102709 Mon Apr 16 2007 9:16pm
The doc
I'm not going there Whistle
Post #102717 Mon Apr 16 2007 9:28pm
Brian Mason
Spoilsport! Ner Ner MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #102719 Mon Apr 16 2007 9:31pm
YY
No there's no previous owner, I just live in London and work close by so that explains the low mileage. The LR assistance guy was very surprised that he could not connect to the car, which doesn't sound great. He seemed to think it was a problem derived from the main electronic system not necessarily an actual suspension fault.
Doc I've had your problem with the bushes and it got fixed in early March after several trips to the dealer, though while it sounds much better, I think I still hear clunk now and then.
Post #102721 Mon Apr 16 2007 9:34pm
Re: Serious or not?
Hello YY ....
I too have a SEPT 05 [ 55 ] Supercharged - but I have covered an imense 15000 miles ... Wink joking apart I had exactly the same problem - turned out to be a completely NAF - Dead Battery causing all my faults/alarms and eventual dead car - same as yours.
Hope this is the case - as simple to fix. Car was only a few months old - if you do a search in " My RRS " section you will find all the details with regard to this.
Martin
Post #102738 Mon Apr 16 2007 10:46pm
Brian Mason
Thought that would be it MDP! Thumbs Up MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #102741 Mon Apr 16 2007 10:59pm
Found it YY ... take a look through my experience http://www.rrsport.co.uk/forum/topic356-30.html
Post #102743 Mon Apr 16 2007 11:04pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
This oldie (but goodie) Tech Service Bulletin may also apply to your situation... Good luck!
Quote:
TSB SECTION: 414-01
Battery Junction Box Connections
AFFECTED VEHICLE RANGE:
Range Rover Sport (LS) VIN: ALL
CONDITION SUMMARY:
INOPERATIVE ELECTRICAL FEATURES
A customer may report a variety of concerns relating to warning lamps being displayed on the instrument pack or inoperative electrical circuits.
Cause: Diagnosis may indicate power supply problems. The complaints may be as a result of a poor connection or damaged / dislodged terminals in the battery junction box (BJB).
Action: Upon customer complaint of this type of electrical fault, refer to the Repair Procedure detailed in this bulletin for troubleshooting and corrective action.
PARTS:
Information Only
TOOLS:
YRW500030.............Wiring connector extraction tool (part of the wiring harness repair kit).
Post #102746 Tue Apr 17 2007 2:54am
YY
Thanks a lot guys.. will update you.
Post #102758 Tue Apr 17 2007 7:45am
Brian Mason
Good luck YY. Glad it's not looking serious.., as I suspected & hoped! Thumbs Up MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #102930 Tue Apr 17 2007 6:11pm
YY
According to the service guy, there is a fiber optic cable that links all the electronic devices in the car. There are 5 or 6 modules connected to this fiber optic cable. This cable was being "pinched" somewhere, and this leads to the disabling of all the modules.
Post #103296 Wed Apr 18 2007 2:38pm
