![]() | Home > General > Serious or not? |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Sounds like a battery or power supply issue. Low battery output can send "ghost" messages. TB would be the man to ask. Doesn't sound major though and it's under warranty so dont worry! Good Luck! |
Sounds pretty serious if Land Rover assist cannot get it to do anything at the roadside.......... these guys are usually pretty good at getting you going again when the electronics play up. I wonder if because of it's age and exceptionally low mileage it hasn't had the various electronic upgrades done at service time - are you the first owner of the car? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
I've had simillar problems... |
Go on then Doc.., dont be a tease! ![]() |
I'm not going there |
Spoilsport! |
YY Member Since: 11 Jul 2006 Location: London Posts: 23 ![]() ![]() ![]() |
No there's no previous owner, I just live in London and work close by so that explains the low mileage. The LR assistance guy was very surprised that he could not connect to the car, which doesn't sound great. He seemed to think it was a problem derived from the main electronic system not necessarily an actual suspension fault.
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Hello YY .... I too have a SEPT 05 [ 55 ] Supercharged - but I have covered an imense 15000 miles ... ![]() Hope this is the case - as simple to fix. Car was only a few months old - if you do a search in " My RRS " section you will find all the details with regard to this. Cheers Martin ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Thought that would be it MDP! |
Found it YY ... take a look through my experience http://www.rrsport.co.uk/forum/topic356-30.html |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
This oldie (but goodie) Tech Service Bulletin may also apply to your situation... Good luck!
Thanks a lot guys.. will update you. |
Good luck YY. Glad it's not looking serious.., as I suspected & hoped! |
According to the service guy, there is a fiber optic cable that links all the electronic devices in the car. There are 5 or 6 modules connected to this fiber optic cable. This cable was being "pinched" somewhere, and this leads to the disabling of all the modules. |
