![]() | Home > Technical > odd noise when reversing on full lock |
Not had it on the RRS, but I did have it on a previous car. Was a worn CV joint in the rear axle... I wouldn't expect that on a brand new car but stranger things have happened. You wouldn't have expected to have have your car put through a full wheel alignment after a short time out of the factory! |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
Not at access height? D3 clonks on full lock at access height. |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
not sure if it IS at access height only, will check that next time I go out and see if it does it in access or normal height. L319 D4 HSE
I keep getting this weird clanking/banging noise when reversing on full lock slowly at access height. Definitely coming from the front wheels, it's so noisy that bystanders look at the car, expecting to see that I have hit something perhaps or watch bits fall off.
byron Member Since: 06 Jan 2006 Location: Athens Posts: 91 ![]() ![]() ![]() |
Have you by any chance put wider tyres? RRS S/C,Bonatti Grey,Ebony Interior,Lined Oak Finish, Rear Lock Dif, DVD,Sunroof,ACC |
Nope, it is a standard Supercharged configuration with 20" alloys and 275/40/R20 Contintental Sport Contact tyres L319 D4 HSE
Strange, had the same problem with a Jeep Wrangler I had 4-5 years ago but apparently it was due to the fact that when at full lock the wider tyres would scrape the chasis and bounce back, but in your case, you d better check it |
Its a normal feature D3s do it too. |
Sounds like what the dealer might say...I might call them today and ask if they have heard of it. L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263 ![]() ![]() ![]() |
I get quite a loud scraping type noise from the right front wheel when I am at full lock in access mode (in multi storey carparks normally). Dealer claims its perfectly normal but did say that I shouldn't be driving (even in carparks) in access mode. This defeats the purpose of being able to lock it in access! 2013 RRS SDV6 Autobiography Fuji White
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Tell your dealer " Boll***s" the entire setup ( ride height ) is governed by pre determined/set speed limits. Will remain at access height untill speed exceeds 6mph Wont drop to access height untill vehicle slows to below 6mph and does not light up the symbol until 5mph. CRAWL MODE This mode enables the vehicle to be driven at low speeds at access height to give increased roof clearence in low car parks ,etc. Crawl can be selected when the vehicle is below ( 22mph ) . When locked in this mode , normal on road height will be selected automatically if the vehicle speed exceeds 24mph So again you should tell your dealer to read his handbook ![]() ![]() ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
I have the car booked in for this issue and couple of others, they said they had heard it before, and recently in particular on a D3 being moved about in the showroom, said someting to do with the steering lock stops having not been adjusted at PDI.
OzzieSport Member Since: 05 Jan 2006 Location: Brisbane Posts: 4 ![]() ![]() ![]() |
I heard it on my vehicle - 18inch wheels. Only has happened on full lock in access height .
Huggy Bear Member Since: 27 Jan 2006 Location: Midlands Posts: 2 ![]() ![]() |
Hi RRUK,
