![]() | Home > Maintenance & Modifications > Water in headlight |
I have somehow got a fair bit of water in my 2 headlights. I have taken the units off and see that they are not water tight. I have drained as much as possible and hope that the heat of the lights will evaporate the remaining water. Has anyone else had this issue? 2005 Zambezi TDV6 - Gone but not forgotten
modbarra Member Since: 10 Jan 2008 Location: northampton Posts: 43 ![]() ![]() ![]() |
Had fair amount of water in one headlight following outing at Yarwell...... took to dealer who replaced under warranty without any hesitation |
Better get the car into the dealer quick then VA before the warranty runs out! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
It's in tomorrow! 2005 Zambezi TDV6 - Gone but not forgotten
Hope they don't consider it "fair wear and tear" ........................ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
They shouldn't - only happened when wading which this car should handle. 2005 Zambezi TDV6 - Gone but not forgotten
bungee Member Since: 17 Aug 2007 Location: a lovely place Posts: 16 ![]() |
are the headlights not higher that the recomended wading depth ![]() |
But you get a decent bow wave that will come over the bonnet and be lower than the intake if you go in properly! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
But when you wade you create a bow wave which is higher than the max wading depth. 2005 Zambezi TDV6 - Gone but not forgotten
when you create a bow wave it is in front of the vehicle ,so should not be able to get in the rear of the headlight the same way as it does not enter the air intake ,if it is entering the headlights this way the headlights are faulty |
Exactly. 2005 Zambezi TDV6 - Gone but not forgotten
