Home > Maintenance & Modifications > Headrest/Roofscreens etc etc
Page 3 of 3 <123
I just think it looks a bit bulky especially with the screen down. It will also cut off the view from your reiw view mirror. 2005 Zambezi TDV6 - Gone but not forgotten
Post #8137 Fri Dec 16 2005 12:44pm
Another option would be to fit 2 - one each side behind each seat as in the Disco3 Question
Expensive though Sad
see example here http://www.prestigeaudio.co.uk/auto/discov...39-89.html
Post #8141 Fri Dec 16 2005 12:56pm
Prestige Audio
Is there an echo in here?!!!! Wink
Roofscreen package 2
Twin Alpine 10.4" roofscreens (one either side)
Alpine DVD player
2 pairs Alpine headphones
Usual price £1995
RRSport forum price - £1680
Two drop down screens would be the nuts! The Alpine is very slim when closed, but does totally block the rear view mirror when open, hence the twin screen option which gives you a large screen and none of the other issues.
The eagle eyed out there will have spotted that on the single roofscreen install we have to move the alarm sensors a little but as the alarm self calibrates on arming, this isn't an option (although I wouldn't advise leaving the screen down when leaving the car for a while as it will block the alarm's coverage of the boot area.
Post #8142 Fri Dec 16 2005 1:03pm
Martin
Site Administrator & Owner
Chris did you get my latest e-mail? Like this site? Buy some RRSPORT goodies to show your support!
Post #8147 Fri Dec 16 2005 1:08pm
Prestige Audio
Hi Martin,
i didn't see it?
C
Post #8148 Fri Dec 16 2005 1:10pm
Bontempi
Sweden
Prestige Audio wrote:
Biggles wrote:
My question can you make the logic seven sound like the extra grand should, that you pay from new. Question
Nope, as the saying goes, you cannot polish a turd!!!
However, a grand spent on an aftermarket system would send pretty special!
Is there a way to get a an analogue line level output from the head unit, and install aftermarket amps and speakers? A 2-channel signal would be sufficient for me.
/Bontempi
Post #8687 Thu Dec 22 2005 6:43pm
grommet
United States
Not really or easily since the amplifier is connected to the head unit via MOST. You can use a JL CleanSweep to convert 4 current amplifier outputs into a 4 "re-equalized" line-outs, but you might need to never touch your volume again if the system does volume based equalization.
Supposedly someone has a MOST device that will give you line-out, but I haven't seen it in action.
Post #8692 Thu Dec 22 2005 9:01pm
Bontempi
Sweden
grommet wrote:
Supposedly someone has MOST device that will give you line-out, but I haven't seen it in action.
If anyone has information on such a device, I would be very interested. The
head unit looks so tightly integrated in to the car, that it cannot be replaced.
So my plan is to
get the system without Logic 7, upgrade speakers and amps, and use an
iPod with "Apple lossless" files as my music source.
Promlem is, my bikes didn't fit inside the RRS, so I'll be heading to the Disco 3 forum now. Razz
But i will keep monitoring this thread...
/Bontempi
Post #8767 Fri Dec 23 2005 12:24pm
Prestige Audio
I have never seen a MOST interface which gives you an analogue RCA output but would also be interested in seeing one!
There is always a solution to such challenges - we generally install a stand alone system in such vehicles with the second head unit installed somewhere also such as the ashtray:
or the rooflining:
or anywhere else for that matter!!
This gives you carte blanche to install some juicy amps and speakers!
Post #9476 Thu Jan 05 2006 10:30am
Bontempi
Sweden
A standalone system is always an option of course, but I'd like to keep
the Navigation and PTI etc. I am sure it can be done, but it will
be a bit complex... Smile
I am a bit surprised that no vendors offer amps with MOST input
or a solution for integration with analogue signals. It is obvious the car makers are heading in that direction,
and if the aftermarket doesn't adapt it will disappear.
/Bontempi
Post #9547 Fri Jan 06 2006 9:22am
grommet
United States
I tracked down the person that told me he had access to a MOST interface with line out capability for Land Rover. It turns out he doesn't and it's for some BMW system. He thought Land Rover still used BMW head units, like pre-05 Range Rover. Sorry.
Post #9548 Fri Jan 06 2006 9:40am
Page 3 of 3 <123
