![]() | Home > Maintenance & Modifications > Headrest/Roofscreens etc etc |
I just think it looks a bit bulky especially with the screen down. It will also cut off the view from your reiw view mirror. 2005 Zambezi TDV6 - Gone but not forgotten
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Another option would be to fit 2 - one each side behind each seat as in the Disco3 |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Chris did you get my latest e-mail? Like this site? Buy some RRSPORT goodies to show your support! |
Prestige Audio Member Since: 14 Dec 2005 Location: Rickmansworth, Herts Posts: 31 ![]() |
Hi Martin,
Bontempi Member Since: 30 Oct 2005 Location: Where the gravel road ends... Posts: 17 ![]() ![]() |
Is there a way to get a an analogue line level output from the head unit, and install aftermarket amps and speakers? A 2-channel signal would be sufficient for me. /Bontempi |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
Not really or easily since the amplifier is connected to the head unit via MOST. You can use a JL CleanSweep to convert 4 current amplifier outputs into a 4 "re-equalized" line-outs, but you might need to never touch your volume again if the system does volume based equalization. Supposedly someone has a MOST device that will give you line-out, but I haven't seen it in action. Last edited by grommet on Thu Jan 05 2006 10:37am. Edited 2 times in total |
If anyone has information on such a device, I would be very interested. The head unit looks so tightly integrated in to the car, that it cannot be replaced. So my plan is to get the system without Logic 7, upgrade speakers and amps, and use an iPod with "Apple lossless" files as my music source. Promlem is, my bikes didn't fit inside the RRS, so I'll be heading to the Disco 3 forum now. ![]() But i will keep monitoring this thread... /Bontempi |
I have never seen a MOST interface which gives you an analogue RCA output but would also be interested in seeing one!
A standalone system is always an option of course, but I'd like to keep the Navigation and PTI etc. I am sure it can be done, but it will be a bit complex... ![]() I am a bit surprised that no vendors offer amps with MOST input or a solution for integration with analogue signals. It is obvious the car makers are heading in that direction, and if the aftermarket doesn't adapt it will disappear. /Bontempi |
I tracked down the person that told me he had access to a MOST interface with line out capability for Land Rover. It turns out he doesn't and it's for some BMW system. He thought Land Rover still used BMW head units, like pre-05 Range Rover. Sorry. |
