Home > Technical > Battery life
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
Battery life
how long is the life for the RRS supercharged battery I feel that It became weak and in cold morning it's hard to start now 13 months of use is that normal 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #156106 Mon Feb 18 2008 7:13am
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
Be sure that it is not normal. It should last for at least 3-4 years or more if you took a good care of it(checking the electrolyte level in the battery) 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #156112 Mon Feb 18 2008 7:59am
It's not unheard of that batteries don't last as long as they might.
MDP had all sorts of problems in his SC caused by a failing battery.
Post #156115 Mon Feb 18 2008 8:24am
Bobby
Nobody, not even the manufacturers can answer that with certainty.
Generally, in our region, if the battery lasts more than a year we're happy. More than 2 years is a bonus!
There have been cases of batteries going flat in a couple of months but of course you can make a warranty claim within the first year (over here anyway).
Markos, in our market the cars come with sealed maintenance-free batteries. So no way to top up the water! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #156259 Mon Feb 18 2008 10:59pm
sportman
ok what are the indications or factors which reduce the life of any range rover sport battery electronics or misusing.. i remeber that I connect air compressor friquantly 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #156271 Tue Feb 19 2008 6:11am
It's common sense really sportman... like you say, running things like air compressors, running the audio long after the engine's off if you've left the ignition on. Batteries do perform differently under different environmental conditions as Bobby says... in the UK, where we don't really have extreme temperatures in either direction, you should really expect a battery to last a good 3 or 4 years. Your mileage may vary.
Post #156285 Tue Feb 19 2008 8:43am
PauloAmore
Scotland
High temperatures will call a batteries capacity to hold charge in the medium to long term.
Believe temperatures as low as 30 degrees can cause this phenomenon.... 2022 P440e AB
Post #156288 Tue Feb 19 2008 8:54am
Bobby
sportman, this is as good an answer you'll get. Any battery, whether for car, RRS, toy, etc. will wear out sooner or later. Misusing will only hasten the process.
There are so many variables involved and you will not get a "right" answer as to the 'life' of a battery. Malaysia Boleh!
Post #156299 Tue Feb 19 2008 9:37am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
The battery of the Sport has the same warranty as the car here in North America, 4 year or 50K miles whichever occurs first. I don't know how it is in the UAE, but you may still be entitled to a free replacement - and have them check the alternator, too.
Post #156359 Tue Feb 19 2008 4:23pm
sportman
due to high temperature here in UAE the average battery life is 18 to 24 month I'm 13 month right now 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #156405 Wed Feb 20 2008 5:34am
Bobby
You had the answer all along! Laughing Malaysia Boleh!
Post #156407 Wed Feb 20 2008 5:48am
