![]() | Home > Technical > Battery life |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 ![]() ![]() ![]() |
how long is the life for the RRS supercharged battery I feel that It became weak and in cold morning it's hard to start now 13 months of use is that normal 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Be sure that it is not normal. It should last for at least 3-4 years or more if you took a good care of it(checking the electrolyte level in the battery) 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
It's not unheard of that batteries don't last as long as they might.
ok what are the indications or factors which reduce the life of any range rover sport battery electronics or misusing.. i remeber that I connect air compressor friquantly 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
It's common sense really sportman... like you say, running things like air compressors, running the audio long after the engine's off if you've left the ignition on. Batteries do perform differently under different environmental conditions as Bobby says... in the UK, where we don't really have extreme temperatures in either direction, you should really expect a battery to last a good 3 or 4 years. Your mileage may vary. |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
High temperatures will call a batteries capacity to hold charge in the medium to long term.
sportman, this is as good an answer you'll get. Any battery, whether for car, RRS, toy, etc. will wear out sooner or later. Misusing will only hasten the process. There are so many variables involved and you will not get a "right" answer as to the 'life' of a battery. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
The battery of the Sport has the same warranty as the car here in North America, 4 year or 50K miles whichever occurs first. I don't know how it is in the UAE, but you may still be entitled to a free replacement - and have them check the alternator, too. |
due to high temperature here in UAE the average battery life is 18 to 24 month I'm 13 month right now 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
You had the answer all along! |
