Home > Technical > SATNAV and POI
949BFN
South Africa 2007 Range Rover Sport Supercharged Chawton White
SATNAV and POI
Anyone knows if this will work with the RRS system: http://www.pimp-my-nav.com/index.htm (It is an application used to make a copy of the original NAV DVD, adding custom POI (like safety cameras) at the same time.) I suppose the question is actually, does the RRS use the same navigation computer as the FFRR? If not, anyone know of a similar application we can use with the RRS? I have always thought the ability (or actually lack thereof) to add custom POI is the biggest disadvantage of the built in navigation systems. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C)
Post #155093 Sat Feb 09 2008 6:21am
JGreg1
United States 2006 Range Rover Sport Supercharged Java Black
Interesting. Will be curious to see if that will work with RRS Navi, but I fear not.
Post #155149 Sun Feb 10 2008 6:51am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
That won't work. The Denso satnav in use on RRS, 2005+ FFRR and Disco/LR3s is a whole different animal than the one fitted on earlier MY Range Rovers, which used a BMW based satnav shared with most BMWs and Mini. That system was far more "hackable". The new one uses a cryptic file format, making it virtually impossible to crack / modify.
Post #155151 Sun Feb 10 2008 8:12am
That's a sham would be good if you can add your own POI's Sad RRS TDV6 Gone but still around
Post #155163 Sun Feb 10 2008 11:56am
Martin
Site Administrator & Owner
The BMW Nav system is based upon a clear directory structure and uncompressed HTML and text files.
The LR system is based on the KIWI format. Technically it should be able to decode the files as the specifications are available online but, as far as I'm aware, no-one has managed to do it successfully Sad Like this site? Buy some RRSPORT goodies to show your support!
Post #155166 Sun Feb 10 2008 12:18pm
Someone did once say on here, that they would be putting some of their finest minds onto it... and they no doubt ran into the same problems Whistle
Post #155246 Mon Feb 11 2008 10:06am
