![]() | Home > Technical > SATNAV and POI |
949BFN Member Since: 16 Apr 2007 Location: Bloemfontein Posts: 59 ![]() ![]() ![]() |
Anyone knows if this will work with the RRS system: http://www.pimp-my-nav.com/index.htm (It is an application used to make a copy of the original NAV DVD, adding custom POI (like safety cameras) at the same time.) I suppose the question is actually, does the RRS use the same navigation computer as the FFRR? If not, anyone know of a similar application we can use with the RRS? I have always thought the ability (or actually lack thereof) to add custom POI is the biggest disadvantage of the built in navigation systems. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C) |
JGreg1 Member Since: 04 Jan 2008 Location: Rogers, Arkansas USA Posts: 40 ![]() ![]() ![]() |
Interesting. Will be curious to see if that will work with RRS Navi, but I fear not. |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
That won't work. The Denso satnav in use on RRS, 2005+ FFRR and Disco/LR3s is a whole different animal than the one fitted on earlier MY Range Rovers, which used a BMW based satnav shared with most BMWs and Mini. That system was far more "hackable". The new one uses a cryptic file format, making it virtually impossible to crack / modify. |
That's a sham would be good if you can add your own POI's |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
The BMW Nav system is based upon a clear directory structure and uncompressed HTML and text files.
Someone did once say on here, that they would be putting some of their finest minds onto it... and they no doubt ran into the same problems |
