Home > Technical > Tailgate |
I figured it out - the extra weight of the sticker on the tailgate is causing the problem. 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
Wed Dec 14 2005 5:20pm |
Quasimoto Member Since: 27 Jul 2005 Location: Middleburg, VA Posts: 34 |
Martin -- I've been noticing the same squeek/rattle in the past week also. I'm hoping it's due to a small gap that's developed somewhere due to the cold weather (and not a bigger problem!). When I go over speed bumps, it sounds as if the the rear tailgate's not quite closed all the way, but nothing on the display. The sound was so distinct I got out and gave it a good slam. Over the next bump...same thing. I'll be interested to hear what your dealer has to say... -QM |
Thu Dec 15 2005 1:00pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2581 |
On mine there is two rubber stops on each part of the tailgate, so you can do the same for the lower part as you did for the glass part... L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
Thu Dec 15 2005 1:20pm |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
SORRY RRUK - I had'nt noticed this, I did the top glass ones OK , but then looked at the main tailgate rubbers , gave them a twist & thought they didnt screw out like the others, but now, after a second look I have discovered as you quite rightly point out, they do screw out enabling adjustment. So I will play around with these to see if I can cure the rattle THANKS MDP " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Thu Dec 15 2005 3:01pm |
Thu Dec 15 2005 3:09pm |
VA ..... what could you mean......
Thu Dec 15 2005 4:25pm |
of course like mine, if you have had the rear number plate light replaced, you will still have the broken part of the old light fitting rattling about inside the top tailgate cos the monkey who fixed it was not thorough enough to fish out the debris.... L319 D4 HSE
Thu Dec 15 2005 4:51pm |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 |
damn.. i have had this replaced on mine too!
Thu Dec 15 2005 4:57pm |
It would appear that these rubber srew/stops do adjust. Having played around with them I think I have cured the annoying rattle.
Fri Dec 16 2005 12:32pm |
Another result for the RRSport team! 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
Fri Dec 16 2005 12:42pm |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
sorry for diggin up but i have this problem too.
Mon Apr 01 2013 5:35pm |
