Home > Technical > HELP! Completely dead – Nothing happens
Good luck mate. Hope it gets sorted Thumbs Up
Post #134046 Fri Aug 24 2007 10:51am
Best of luck - keep us informed, by knowing someone elses misfortune we can help someone in the future. 2005 Zambezi TDV6 - Gone but not forgotten
Post #134050 Fri Aug 24 2007 10:53am
NYCsport
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
This happened to me once about a year ago and never happened again. A jump start worked for me. I needed to connect the jumper cables directly to the battery terminals to get the Sport to turn over. Run the other car above idle for a few minutes to get the alternator turning out some juice.
Post #134165 Fri Aug 24 2007 3:06pm
Endjin
Scotland
That is shocking service. I would forget the dealer at this stage and contact Land Rover Denmark directly and make a lot of noise about how crap this service is from Land Rover.
Land Rover Danmark A/S
Sjællandsvej 1
DK-6000 Kolding
Tlf: 70 15 15 33
Fax: 76 34 20 77
Best of Luck 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #134171 Fri Aug 24 2007 4:10pm
rrsjo
Sjællandsvej 1
DK-6000 Kolding
Tlf: 70 15 15 33
Fax: 76 34 20 77
Best of Luck
Also ring Land Rover Custormer Services in UK and tell them this is not good enough from one of their dealers.
Post #134173 Fri Aug 24 2007 4:22pm
RRSTDV8DK
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
RUNNING AGAIN !!
I got really tired looking at the possibility of being without my wonderful car for 2-? Weeks and since none of the suggestions that you or the dealer had seamed to work, I decided to try one last thing – a hard reset.
I disconnected the battery for 10 min. and connected it again – AND VOILA, the engine sprang to live with out any hesitation, just as I’m used to.
Everything seam to ok now – although I will go to the dealer on September 4th and get him to do that diagnostic – just to have it checked out.
Thank you for all your input and support.
Regarding the dealer service, I don’t think Land Rover Denmark would do anything, but Land Rover UK might just be the guys to call. Anybody got a number to the right persons? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #134192 Sat Aug 25 2007 12:39pm
Good news! 2005 Zambezi TDV6 - Gone but not forgotten
Post #134200 Sat Aug 25 2007 2:02pm
Cliff H
Check the -ve battery connections to the body, if it is like the TDV6 there are 2.
Just a thought, worth a try, it can play all sorts of fun and games if the connection is a bit dodgy and it happens more times than it should.
Good luck
Post #134211 Sat Aug 25 2007 5:31pm
rrsjo
Re: RUNNING AGAIN !!
I would suggest sending an email to Customer Services asking for the name and email address of the Director who is responsible for overseas dealers - there iis a Director responsible for this dealership somewhere within the organisation. This wiill show Customer Services you mean business and they will either supply you with the details you require and you can then email the Director details of your complaint, or Customer Services will offer to take on your complaint themselves, so that it doesn't go any higher. If you don't get satisfaction from Customer Services then insist you are given the relevant Director's details.
Hope this is of help.
Post #134239 Sat Aug 25 2007 10:04pm
