Home > Technical > use of hybrid tv
Tedf
Denmark 2007 Range Rover Sport TDV8 HSE Java Black
use of hybrid tv
in my new TDV8 I have the TV option. I won't be very popular with the environmentalists around here if I sit and watch TV with the motor running. How long do I dare watch TV while standing still with the motor off without risking running down the battery...if at all? Does it make a difference with which position the key is in?
Thanks
Ted
Post #130818 Wed Aug 08 2007 3:18pm
Imo
Hi Tedf,
I have the TV and RE system and notice that when the ignition is switched off the system goes into low power mode and limits the volume level to a max of 20 and also marginally dims the screens. If left running it automatically powers down after 30 minutes, but can be switched straight back on again, I ran the front and rear screens for 2h30m with no problems whatsoever - British traffic jams!
Hope this helps
Post #130954 Wed Aug 08 2007 9:15pm
Tedf
Thanks very much..a big help.. I would like to watch while I wait to pick up my wife at work...sometimes a half hour...so it sounds safe......
again thanks,
ted
Post #131025 Wed Aug 08 2007 10:07pm
jjb218
2006 Range Rover Sport Supercharged Zermatt Silver
When the battery is draining low, auto shut off
I did the same thing as to switch back and again 2 or 3 times, only this time my screen dimmed, no rear illumination, I thought I burned the screen, but no! It was a security function to shutoff if not complete battery drain very possible!
I carry a battery booster in the trunk, very usefull for any ocassion, plus if you vahe it plugge din the rear cigarrete adapteri t can recharge itself or the car!!DOuble purpose!
Bye
JJB218
Post #132619 Mon Aug 13 2007 8:39pm
