![]() | Home > Off Roading & Green Laning > Serious off roaders |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
Cant say that i have ventured seriously off road with mine, and neither do i want to, but i know that there are a few on here that have,TJ101, VA but to name a few, give em time and you will get some usefull help.
Might also be worth posting this on the D3 site too, they tend to be a bit more muddy than us in general and as the RRS and D3 chassis are the pretty much the same, you'd expect the same mounting points etc. |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
Rear recovery is where the towbar electrics are and the front one is under the plastic cover. They aren't tie down points but are suitable for "proper off roading" |
cotefarmboy Member Since: 16 Feb 2006 Location: West Yorks Posts: 68 ![]() |
Get it muddy with us D3 boys here..............
TJ101 Member Since: 17 Jan 2007 Location: Somerset UK Posts: 207 ![]() ![]() |
Evening Gary, Strange, i also run a 90 V8 as a challenge truck, |
Rangie Member Since: 10 Oct 2005 Location: Sydney, Australia Posts: 34 ![]() ![]() |
I get my off road on a regular basis. Happy to say that i have never needed to be yanked out (although i have come close several times) I would not do a recovery from the front hook, it is a tie down and will break off. The rear point is ideal to be recovered.
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 ![]() ![]() |
As has already been said, the front one is a proper recovery point too, not just a tie down, so don't waste your time |
My LR Dealer said it was not built for recovery. Does anyone know for sure? Ben |
Your dealer is wrong (wouldn't be the first time)
Think Slimer is correct,, will have a look on the G4,,, if it needed beefing up,, LR would have done it on the challenge vehicles |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
had the RRS deep in the mire, good old scottish peatbog and bottomed out even in super-extended mode and had to get pulled out |
Bet it would get through on your MTRs now though! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
It is good to know... I was worried about using it. Ben |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Attach a couple of heavy duty shackles on both recovery points and you'll be ready for the worst. TJ is right, the recovery points on both RRS and Disco/LR3s are basically part of the frame and very strong. According to LR, you can actually use them to lift and suspend the vehicle up in the air. |
