Home > Off Roading & Green Laning > Serious off roaders |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
Cant say that i have ventured seriously off road with mine, and neither do i want to, but i know that there are a few on here that have,TJ101, VA but to name a few, give em time and you will get some usefull help.
Fri Jul 20 2007 7:15am |
Might also be worth posting this on the D3 site too, they tend to be a bit more muddy than us in general and as the RRS and D3 chassis are the pretty much the same, you'd expect the same mounting points etc.
Fri Jul 20 2007 8:20am |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 |
Rear recovery is where the towbar electrics are and the front one is under the plastic cover. They aren't tie down points but are suitable for "proper off roading" |
Fri Jul 20 2007 11:48am |
cotefarmboy Member Since: 16 Feb 2006 Location: West Yorks Posts: 68 |
Get it muddy with us D3 boys here..............
Fri Jul 20 2007 12:19pm |
TJ101 Member Since: 17 Jan 2007 Location: Somerset UK Posts: 207 |
Evening Gary, Strange, i also run a 90 V8 as a challenge truck,
Sun Jul 22 2007 9:11pm |
Rangie Member Since: 10 Oct 2005 Location: Sydney, Australia Posts: 34 |
I get my off road on a regular basis. Happy to say that i have never needed to be yanked out (although i have come close several times) I would not do a recovery from the front hook, it is a tie down and will break off. The rear point is ideal to be recovered.
Tue Jan 01 2008 12:44pm |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 |
As has already been said, the front one is a proper recovery point too, not just a tie down, so don't waste your time |
Tue Jan 01 2008 9:42pm |
My LR Dealer said it was not built for recovery. Does anyone know for sure? Ben |
Tue Jan 01 2008 9:55pm |
Your dealer is wrong (wouldn't be the first time)
Tue Jan 01 2008 9:57pm |
Think Slimer is correct,, will have a look on the G4,,, if it needed beefing up,, LR would have done it on the challenge vehicles If i remember right, its a lot tougher than the normal LR "lashing" eye 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
Tue Jan 01 2008 10:33pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
had the RRS deep in the mire, good old scottish peatbog and bottomed out even in super-extended mode and had to get pulled out used the front recovery eye and had to have a few tugs at it to get the car out.
Tue Jan 01 2008 10:48pm |
Bet it would get through on your MTRs now though! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Jan 01 2008 11:50pm |
It is good to know... I was worried about using it. Ben |
Wed Jan 02 2008 5:57am |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Attach a couple of heavy duty shackles on both recovery points and you'll be ready for the worst. TJ is right, the recovery points on both RRS and Disco/LR3s are basically part of the frame and very strong. According to LR, you can actually use them to lift and suspend the vehicle up in the air.
Wed Jan 02 2008 11:26am |
