![]() | Home > Technical > Navi TMC problem |
mil lamp Member Since: 18 Jul 2007 Location: berks Posts: 4 ![]() |
what station did you find? tmc should be classic fm. |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
I doubt you can get Classic FM in Italy!
Tazio Nuvolari Member Since: 23 Apr 2007 Location: Parma Posts: 15 ![]() ![]() ![]() |
what the differece of "classic Fm" and "Heart Fm", the TMC of bmw works very well without to make changes.
In the UK, the TMC signal is only broadcast on one radio frequency, that of the radio station Classic FM. The situation will be different in Italy.
![]() 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Thank you
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1676 ![]() ![]() ![]() |
This highlights an annoying problem with the TMC system as it tries to auto-search for a station, even though in the UK there is only one. If it can't find a station within a couple of runs around the frequencies it stops.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
If you didn't press 'agree' until you were above ground would it not start searching until then (thus avoiding the problem) or does it search on power up? |
I think it searched before you press agree. I seem to recall times when I havn't needed the sat nav and havn't pressed agree until a lot later and the TMC is up and running. 2005 Zambezi TDV6 - Gone but not forgotten
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
Our TMC keeps retuning itself to Heart FM - no use at all! |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
funny - TMC is very well supplied here in Schnitzelland...
TMC cost us money and the damn thing doesn't work properly - why arn't we insisting that they fix this problem or give us some money back. My TMC works about 50% of the time. 2005 Zambezi TDV6 - Gone but not forgotten
Dead easy, you tune the TMC channel to Classic and it works, you drive around, Classic signal may or may not dissappear and come back, you may, or may not turn the ignition off and back on, eventually you notice that TMC has been off for quite a while, on rechecking you find the TMC channel is now tuned to Heart FM and needs a search forced to find Classic again....repeat as necessary. ![]() ![]() ![]() Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
I never had to physically tune it into a channel when I had mine and I never had any issues with TMC, always worked fine. Likewise the TMC works perfectly well on my 535, also without any input from me to make it work.
