Home > General > Bio Diesel / Shell V-Power
acucobol
The local Morrissons has a bio diesel pump which is En590 compliant. The manual states that you can run the RRS on En590 diesel. Has any tried it?
Conversely has anyone got feedback on the 'super' diesel fuels?
Post #125071 Thu Jul 12 2007 12:55pm
Endjin
Scotland
Don't know about the Bio stuff but My Brother says he notices a difference on his Disco 3 TDV6 when he uses the "premium" Diesel's. He reckons it's a bit quicker and that the engine runs a lot smoother. I haven't tried it myself yet in my RRS. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #125106 Thu Jul 12 2007 3:30pm
Rooleeds
I tried a tank of biodiesel when I had my TDV6, it ran ok, filled up with normal diesel about 3 times after that and then, about 2 weeks later, whilst overtaking on the M621, got ENGING FAULT message, revs dropped to Zero - engine cut out Shocked - I had to put it into neutral, restart the car, and carry on overtaking!!!! All whilst freewheeling at about 70 - ish Whistle
Managed to get it to Rocar Moores Land Rover in Huddersfield, about 15 miles away, having to "restart on the move" about twice more. They plugged it into the computer, the error was caused by restricted fuel flow. So they changed the fuel filter, and all was well, didnt have them the problem again.
Apparently, Biodiesel is a better solvent then mineral diesel, so when you use it, all the gunk, oils, waxes etc, that builds up throughout the enging whilst using mineral diesel, begins to get dissolved and shifted through and ends up clogging the fuel filter.
So if youre going to run on biodiesel only from now on, change the fuel filter a couple of times during your first 1-2000 miles.
ps: I now only use BP Ultimate diesel in the TDV8 and noticed I get about 1-2 mpg more versus regular diesel, not much OK!, also it "seems" a bit more responsive on the good stuff vs the cheaper regular.
Post #125270 Fri Jul 13 2007 1:13am
Josh
I changed to the BP Ultimate diesel with my last RRS and found it ran smoother with slightly better fuel consumption. I understand it burns quicker and cleaner in the engine which has got to be good for it. Will do the same on the new one either BP or the Shell version, which is now more widely available. TDV6 - gone
TDV8 - gone
Post #125310 Fri Jul 13 2007 8:21am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Is the extra cost of the BP Ultimate fuels actually worth it if it only produces an extra 1 or 2 MPG ?
What other benefits are there? Apart from the obvious Nectar points? Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #125339 Fri Jul 13 2007 12:14pm
Josh
For me it just seemed to have more power and ran smoother. Also slight increase in mpg. Also they say it burns cleaner and quicker. So better emmisions unless you drive a cow Laughing
Which is exactly what BP/Shell say.
Give it a go. Its not much more. TDV6 - gone
TDV8 - gone
Post #125440 Fri Jul 13 2007 4:39pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
I switched to BP Ultimate as recommended by DOC, not as much smoke now Whistle and it does seem to be a little more responsive Cool some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #125444 Fri Jul 13 2007 5:35pm
