Home > Technical > Can you run the fuel tank completely dry?
Page 3 of 3 <123
Whistle Whistle 2005 Zambezi TDV6 - Gone but not forgotten
Post #125931 Mon Jul 16 2007 9:24pm
ENVOY wrote:
Big Cry Im telling my mummy about you lot Big Cry Big Cry
aljo, dont forget you only drive a V6, and i have a V2 if you had forgotten Whistle Whistle
Angel's got a few of those left over from WW2! Laughing
Post #125932 Mon Jul 16 2007 9:25pm
aljo
only a V2 ? Shocked thats a very little engine to be carrying your mass bulk around Shocked Whistle
i can imagine it struggles a bit Laughing
Post #125933 Mon Jul 16 2007 9:26pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
I have been tampered with Shocked Shocked
Someone has stolen 6 of my cylinders Shocked i will have to get pussy to push harder Whistle or is that my job Twisted Evil some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #125948 Mon Jul 16 2007 9:39pm
aljo
thought that was cliffs job ? Shocked
Post #125949 Mon Jul 16 2007 9:40pm
rodsport
re qns regarding gas remaining - the system is one similar to BMW and you will get a different reading depending upon;
ambient temperature
temperature of gas and gas tank
historic fuel usage (last few kms etc)
ie point is that when the temp changes from shut down to start up you will be given different values based upon the above and other parameters (as parameters change - eg fuel density and therefore volume changes to give a different reading)
that said - to avoid expensive mistakes, find a garage in good time (not at zero km) - or do you want to be towed home for losing a game of chicken (even if clarkson thinks it is cool) and be the recipient of a massive bill into the bargain
Post #126143 Tue Jul 17 2007 5:48pm
clutchdust
shmoogle wrote:
clutchdust wrote:
it wont do it any harm to "run it out". It will never run out, there is always 10 litres of fuel in there to keep the system wet, ECU goes into "run out of fuel strategy" which means it will turn off injectors to give a surge and a missfire then stop, you will then need to put in at least 10 litres to get it running again.
So what you're saying is that if the system detects less than 10 litres of fuel, then it shuts itself down - the end result being that the car stops itself from running dry? Confused
Yes, if the high pressure pump runs dry, it will kill it as the diesel is a lubricant, this system prevents that, so basically, there is always 10 litres of unusable fuel in the tank to keep the system wet even if the gauge is on its lowest point and the range says 0 miles.
Post #129598 Fri Aug 03 2007 6:20pm
Thumbs Up Thumbs Up
Post #129600 Fri Aug 03 2007 6:24pm
Page 3 of 3 <123
