Home > Maintenance & Modifications > Damp passenger footwell
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
My RRS has developed a very dank and musty smell in the cabin. A bit of investigation reveals a rather damp passenger footwell. There hasn't been any rain, the car hasn't been washed for over a month and no leakey dogs or children have been in it. Any ideas ? RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #111014 Fri May 25 2007 6:15am
Tim in Scotland
Smarticus, I would suggest that an aircon drain is blocked/ nipped behind the dash. It's quite common on all makes of car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #111015 Fri May 25 2007 6:18am
Smarticus
Thanks Tim, quick response ! But what is that, where is it, and what to do ? RRS TDv8 HSE Rimini
Post #111016 Fri May 25 2007 6:26am
Tim in Scotland
You might find it in the owners manual, but I think that with your car being so new a trip to the dealer for the dash board dismantling might be in order...................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #111018 Fri May 25 2007 6:34am
mlines
Usually the actual pipe blocked is outside the car. On air-con cars there is a condensate drain tube that comes out often down the side of the transmission at the rear of the engine. This is what produces the pool of water under the car on warm days. This gets blocked by dirt (have you been off-roading recently?) and the water builds up in the bottom of the air-con and then eventually comes out through the footwell vent in the passenger side. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #111022 Fri May 25 2007 7:15am
rrsjo
Smarticus:
Previous posts have suggested that an aircon condensation pipe, located at the top of the passenger footwell, falls off its connector and hangs loose. Have a look under there to see if there is a loose pipe hanging down. If so, look for the corresponding connector and just push the pipe back on. Apparently it's happened to others. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #111023 Fri May 25 2007 7:45am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Smarticus, PM me your e-mail address, I have a TSB that may help you identifying the source of this leak.
Post #111028 Fri May 25 2007 10:09am
nuke
Romania 2006 Range Rover Sport TDV6 HSE Java Black
"...I have a TSB that may help you identifying the source of this leak..."
anyone knows the TSB no?
or where can it be downloaded?
thanks
Post #565837 Tue Sep 25 2018 12:01pm
