![]() | Home > Maintenance & Modifications > Winch fitting |
I've had a winch mount fitted (waiting for the winch) and her are a few photos. The number plate will be moved once the winch is fitted. One problem is that you lose 2 of the parking sensors so I need to get the ECU reprogrammed to disable the front parking senors so that the rear ones work. Not sure if the ECU can be programmed to accept only 2 of the 4 front sensors to work - any ideas?
TonyMeg Member Since: 10 Feb 2007 Location: North East Posts: 128 ![]() ![]() ![]() |
Drill a couple of new holes & move them along a bit |
That's what I thought - do you speak from experience? 2005 Zambezi TDV6 - Gone but not forgotten
Given it's the central two sensors, that shouldn't pose much of a problem for coverage either! |
Nope just a guess ![]() |
Just searched for G4's & i think only the outside senors are left on the car VA??
bkehoe Member Since: 26 Feb 2006 Location: Wexford Posts: 35 ![]() ![]() |
Relocating is an option too BTW, but you'd need to be sure that they're far enough away from the winch mount to ensure they don't detect it! So if you got it wrong, you'd be left with holes in the bumper! |
So do you know the operating range of a single PDC sensor? |
You have a pm. 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
The operating range is supposed to be 1m in any direction, if it is distance you are meaning shmoogle! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
This is what I'm meaning! |
I wonder how the G4's get round it, I wonder if it is possible to "extend" the sensor wires and remount them on the winch tray.
Tim - will be using bkehoe solution.. No wiring yet as this is being done by someone else. 2005 Zambezi TDV6 - Gone but not forgotten
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
VA - looking good |
