![]() | Home > Technical > CJB Replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Could you just perhaps bridge the o/s to the n/s light, or take a wire from towbar brake light feed as a temporary measure. Don't know if it would work, only a suggestion.
Michael997 Member Since: 31 Jan 2006 Location: Worcestershire Posts: 232 ![]() ![]() |
Thank you Col, unfortunately your suggestion is probably beyond my skill set ☹️
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4441 ![]() ![]() ![]() |
Done this in the past. A bit bodgey, but it works fine, and hugely cheaper
Was only suggesting it as temp. measure until he can get it sorted correctly. Not really difficult to try, but easy to say I guess if anyone has the confidence to give it a go, couple of red scotch locks and 3 meters of wire from the likes of Halfords, pop out both rear light units takes about 30 seconds each or ask the local thieving scrote to do it for you |
