Home > Technical > CJB Replacement
Michael997
CJB Replacement
My local L/R specialist has had a look into why my n/s brake light isn’t working and has diagnosed an issue in the CJB but he cannot fix due to the programming of it.
Can anyone recommend a reliable specialist who could fix this as the main dealers are booking into May and I want to use my car now.
I am near Worcester
Thanks Michael
2013 RRS diesel Autobiography Dynamic
Post #647450 Thu Mar 27 2025 1:25pm
Could you just perhaps bridge the o/s to the n/s light, or take a wire from towbar brake light feed as a temporary measure. Don't know if it would work, only a suggestion.
Wouldn't let a main stealer anywhere near it, for a start they are going to charge you £750.00 for a new CJB and probably create more issues than you started with.
Post #647452 Thu Mar 27 2025 8:24pm
Michael997
Thank you Col, unfortunately your suggestion is probably beyond my skill set ☹️
I agree main stealer are last resort and a risk to my car and my wallet Michael
Post #647454 Fri Mar 28 2025 6:27am
Disco_Mikey
Done this in the past. A bit bodgey, but it works fine, and hugely cheaper
Only ever done it woth LED lamps, as the current draw is hugely lower than that of filament bulbs...
Post #647455 Fri Mar 28 2025 7:18am
Was only suggesting it as temp. measure until he can get it sorted correctly. Not really difficult to try, but easy to say I guess if anyone has the confidence to give it a go, couple of red scotch locks and 3 meters of wire from the likes of Halfords, pop out both rear light units takes about 30 seconds each or ask the local thieving scrote to do it for you Laughing. Green and Purple wire on the plug/connector for each lamp and connect one side to the other and see if that works, would have thought the worse you can do is blow a fuse.
Post #647456 Fri Mar 28 2025 7:52am
