Home > Technical > It’s broke!
Rach
It’s broke!
Hey I’m new, I’ve also done a search but nothing came up for the fault code. We’ve got a 2012 sport which has been great. Had a full service Monday just gone then yesterday driving along the red triangle came up with the words ‘Restricted Performance’ then went into limp mode. Luckily I was next to my house so parked up and left it. Upon starting the red triangle is still there. I have top cover with AA which includes parts and garage cover up to about £500 which is something I guess. They came out this morning and he said the code P1247 come up and he believes it’s the turbo. The pipes on the turbo are inflating fine so he’s unsure. It also flashed up on his reader something about the EGR valve. We’ve taken it to the local garage to me looked at Monday morning. Upon driving it’s ok on the flat, happy at 60mpb on the small dual carriageway but couldn’t even manage 8mph up a hill (we were followed by the AA truck and it wasn’t far)
So there is stays until the garage open on Monday. Does anyone have any clue at all what could be wrong? Thank you.
Post #647280 Sat Mar 15 2025 1:46pm
Should be a couple more digits with that code, if it is -00 it looks like that code may well be associated with another code or codes to narrow it down a bit more.
Post #647291 Sat Mar 15 2025 9:24pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
You made the mistake of letting a garage/dealer touch it.
If you cannot do it yourself best sell it Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #647297 Sun Mar 16 2025 10:13am
Disco_Mikey
That's a helpful response Rolling Eyes
Spend 3k on a dealer diag system, another £5-6k (at least!) on tools and equipment so you can fix it yourself, or sell it
Post #647299 Sun Mar 16 2025 10:55am
Pistnbroke
It is in fact the most helpful response you will get
£120 on a good scanner a set of sockets and spanners along with some trolley jacks and ramps and you are away. Always listen to old people or when they die you will live on in ignorance.
Post #647302 Sun Mar 16 2025 11:52am
Disco_Mikey
And follow a Facetube "expert" no doubt Laughing
Post #647303 Sun Mar 16 2025 1:36pm
Rach
I think that’s the only code, apart from something about the EGR valve. The garage aren’t confident in finding/fixing so suggested another local garage which deals with these cars more.
What could throw a P1247 - low turbo boost pressure code and a EGR valve code? There’s no extra noises/smoke, only runs in limp mode and only manages about 8mph up hill (AA getting it to a garage)
Meanwhile I’m paying over £70 per day on a hire car 😭
Post #647331 Tue Mar 18 2025 9:40pm
Pistnbroke
Needs a smoke test could be cracked inlet manifold. Always listen to old people or when they die you will live on in ignorance.
Post #647332 Wed Mar 19 2025 7:34am
You can do a rough check for an inlet manifold crack by doing a TC stall test. Clear the error message, stand on the brake with the left foot, put it in drive and apply the throttle until the revs stop climbing. A cracked manifold will whistle and the restricted performance message will reappear. 2012 SDV6 - it's missing a couple of cylinders
Post #647333 Wed Mar 19 2025 9:51am
Pistnbroke
or take out the air filter ...block off the box air inlet and set off a plumbers smoke bomb in a tin in the air box....seal crack with JB weld and fish plates as LR Time ...
Oh sorry you cannot do that you took it to a garage... Always listen to old people or when they die you will live on in ignorance.
Post #647335 Wed Mar 19 2025 10:45am
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Hardly useful advice, if you can take the time to type it out, why take the p*ss? 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #647338 Wed Mar 19 2025 2:52pm
Pistnbroke
Just making the point that once you let it out your hands you are powerless....Unless its for a job you have had a quote for like changing a rear oil seal that maybe you cannot do yourself.
The cheap smoke test I suggested works well Always listen to old people or when they die you will live on in ignorance.
Post #647339 Wed Mar 19 2025 3:25pm
windsorlad111
Canada
Your responses are coming off as rather sh*tty, whether you see it or not.
I've had numerous JLR cars, done a ton of work myself and they still have to go in to the pros for things I am not comfortable tackling.
Post #647340 Wed Mar 19 2025 6:41pm
Disco_Mikey
P1247-00 is a generic "Low Boost Pressure" code
The causes are either:
Turbocharger/s not generating enough pressure
A lack of air drawn into the turbo
A boost leak between the outlet of the turbo and the inlet valves of the engine
A restriction in the exhaust, preventing the turbo from spinning properly
By far, the most common issue is a split inlet manifold. Lift the engine cover and look for oil and/or soot staining on the plastic manifolds
Ideally, we need a bit more information about when and how the fault occurs (full throttle or coasting, primary or secondary turbo actuation etc) but first place to check is the inlet manifolds. After this, it does take some in depth diagnostic work Thumbs Up
Post #647341 Wed Mar 19 2025 7:35pm
He can go to the garage and ask them to do a test. Many places are actually keen to learn so that they can do stuff in future. 2012 SDV6 - it's missing a couple of cylinders
Post #647343 Wed Mar 19 2025 11:15pm
