![]() | Home > Technical > It’s broke! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Should be a couple more digits with that code, if it is -00 it looks like that code may well be associated with another code or codes to narrow it down a bit more.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
You made the mistake of letting a garage/dealer touch it.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
That's a helpful response |
It is in fact the most helpful response you will get
And follow a Facetube "expert" no doubt |
Rach Member Since: 15 Mar 2025 Location: Devon Posts: 2 ![]() |
I think that’s the only code, apart from something about the EGR valve. The garage aren’t confident in finding/fixing so suggested another local garage which deals with these cars more.
Needs a smoke test could be cracked inlet manifold. Always listen to old people or when they die you will live on in ignorance.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
You can do a rough check for an inlet manifold crack by doing a TC stall test. Clear the error message, stand on the brake with the left foot, put it in drive and apply the throttle until the revs stop climbing. A cracked manifold will whistle and the restricted performance message will reappear. 2012 SDV6 - it's missing a couple of cylinders
or take out the air filter ...block off the box air inlet and set off a plumbers smoke bomb in a tin in the air box....seal crack with JB weld and fish plates as LR Time ...
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 204 ![]() ![]() ![]() |
Hardly useful advice, if you can take the time to type it out, why take the p*ss? 2018 Telsa MS
Just making the point that once you let it out your hands you are powerless....Unless its for a job you have had a quote for like changing a rear oil seal that maybe you cannot do yourself.
windsorlad111 Member Since: 03 Jul 2024 Location: Toronto Posts: 2 ![]() ![]() |
Your responses are coming off as rather sh*tty, whether you see it or not.
P1247-00 is a generic "Low Boost Pressure" code The causes are either: Turbocharger/s not generating enough pressure A lack of air drawn into the turbo A boost leak between the outlet of the turbo and the inlet valves of the engine A restriction in the exhaust, preventing the turbo from spinning properly By far, the most common issue is a split inlet manifold. Lift the engine cover and look for oil and/or soot staining on the plastic manifolds ![]() ![]() Ideally, we need a bit more information about when and how the fault occurs (full throttle or coasting, primary or secondary turbo actuation etc) but first place to check is the inlet manifolds. After this, it does take some in depth diagnostic work ![]() |
He can go to the garage and ask them to do a test. Many places are actually keen to learn so that they can do stuff in future. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
