Home > Maintenance & Modifications > 6 pot callipers
markiep1
6 pot callipers
Hi all, I’ve been offered a set of 6 pot callipers to replace the standard slider callipers on my 2018 3.0 diesel. I just wanted to see if this is a straight swap or would I require different carriers, they came from a 2.0 P400e I’m guessing the discs will be slightly bigger which is no problem other than perhaps advise on make to purchase Smile
Post #647273 Sat Mar 15 2025 11:25am
Can't really answer your question totally, but would think the callipers would be the same as used on other models, the six pots do not use a separate carrier as they bolt straight on to the knuckle assy. where the carrier would normally bolt on, also the discs for the 6 pot are 380mm dia. so you would probably need those, the backplates I believe on your car would be o.k.
Post #647328 Mon Mar 17 2025 10:55pm
