![]() | Home > Maintenance & Modifications > 6 pot callipers |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5061 ![]() ![]() ![]() |
Can't really answer your question totally, but would think the callipers would be the same as used on other models, the six pots do not use a separate carrier as they bolt straight on to the knuckle assy. where the carrier would normally bolt on, also the discs for the 6 pot are 380mm dia. so you would probably need those, the backplates I believe on your car would be o.k.
