Home > Technical > Glow Plug Measurements
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi all. Thought that since it's a bit milder i would start looking at issues with my Sport.
1st being that during winter, minus 5 or 6 it would struggle to start. But in all fairness I think it shouldn't.
Anyhow, set multimeter to 200 ohms and here's my findings.
Bank 1, drivers side,brown lead.
1 @ 1
1 @ 00.8
1 @ 17.9
Bank 2, pass side,black lead
1@ 148.0
1@ 1
1@ 1
Are my readings done correctly and if so have I got 2 plugs needing changed?
Any advice warmly received as always.
Post #647179 Wed Mar 05 2025 4:44pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
For good winter starting on the 2.7 you need a 2.2K resistor across the temp gauge sender ..its RHS radiator hose . This is the equivalent of pouring hot water on the sensor .
Second the plugs are wired in pairs...at the rear of the fuse box are 3 large fuses. Best to pull them out and bypass with an ammeter 0-20 A . Once they warm up current will drop to about 19A
I only have 2 working on mine and having watched LR time I am not changing them.
Looks like you have 1 plug working..some meters read 0 when its infinity and only the 0.8 cold looks right Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #647189 Thu Mar 06 2025 5:10pm
Toonraider
No need for bypass as I have remote operated pre heater gizmo which i use when it's really cold, run for about 10 mins and it starts fine. Just more concerned about unburnt fuel smoke from exhaust when I don't use it.
And to be honest I've got no clue on resistor fitting or amps at the fuse box.
Post #647190 Thu Mar 06 2025 6:17pm
yeah 2 GP not working.
I would expect it to start with 4 working.
Usually its only a problem at or below 0°C (on the early 2005 engines)
Do you have a DPF ?
Post #647191 Thu Mar 06 2025 6:31pm
Toonraider
Yeah mate. It starts but a bit lumpy for a few seconds or so.
Is there a way to find out which pin connects to which plug?
Post #647192 Thu Mar 06 2025 9:21pm
See last post
https://www.rrsport.co.uk/forum/topic49539.html
But check before actually removing gp’s
Post #647204 Sat Mar 08 2025 7:46am
Pistnbroke
Below Zero deg the ECU increases fuel to the point where the engine is flooded and does not atart ...hence the hot water trick.
If you read your own post mentioned above you will see he has 1 GP working the 0.8 ohm one . all the
1 are 0pen circuit and the higher readings failing. If it was 1 ohm it would read 1.00 Always listen to old people or when they die you will live on in ignorance.
Post #647208 Sat Mar 08 2025 9:48am
Arh. Good point.
My bad for posting when asleep
Post #647210 Sat Mar 08 2025 12:22pm
