![]() | Home > For Sale & Wanted > [Wanted] 100% Diesel |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
Tree huggers look away!
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Or slightly older and get the last of the SDV8. I think they would be 2017. 2012 SDV6 - it's missing a couple of cylinders
Thanks for replies so far.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1878 ![]() ![]() |
Yes it was, but I thought you did not want any of the hybrid stuff?
Thanks, have been doing a bit of research and it seems you cant get a D300 without the mild hybrid stuff. Shame really but there it is. Probably just going to have to put up with it if I want the newer engine.
sacimiddx Member Since: 02 May 2013 Location: winchester Posts: 41 ![]() ![]() |
The mild hybrid is unnoticeable on the D300 just helps with reducing stepping off lag and spooling up the turbo I think
The MHEV is basically just regen braking and then using the battery to help improve acceleration. It uses a combined starter/generator to harvest energy when slowing down and then gives a bit of extra torque to the engine when pulling away again. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
