![]() | Home > General (L494) > Do 6 pot Brembos fit facelift L494 MY18+ |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 85 ![]() ![]() |
Straight forward swap. I did it a few months ago. Had to trim the dust guard at the bottom slightly. You need to go to the 380mm discs and pads and obviously do a full fluid / flush bleed. |
Gassman Member Since: 28 Jan 2025 Location: Notts Posts: 10 ![]() ![]() |
Thanks for confirming, I’m assuming the brake pipe banjo connection is the same on the calipers?
Yep brake lines are the same. The calipers are sided and designed to hold a nipple / extension lug on the line and fits the smaller or larger calibers.
I’ll get ordering the parts. Thanks for the info and tips, will let you know how I get on in a few weeks. |
