Home > General (L494) > Do 6 pot Brembos fit facelift L494 MY18+
Gassman
Has anyone converted the small brake L494 to the 6 pot brembo calipers and bigger discs? Wondered if it’s possible or are the struts different and caliper mountings?
Post #646907 Fri Feb 14 2025 12:19am
Nick900
Straight forward swap. I did it a few months ago. Had to trim the dust guard at the bottom slightly. You need to go to the 380mm discs and pads and obviously do a full fluid / flush bleed.
Post #646919 Fri Feb 14 2025 2:49pm
Gassman
Thanks for confirming, I’m assuming the brake pipe banjo connection is the same on the calipers?
When you did the brake fluid flush and refill did you need a Gap tool or is it a standard system that can be pressure bled?
Post #646928 Fri Feb 14 2025 10:26pm
Nick900
Yep brake lines are the same. The calipers are sided and designed to hold a nipple / extension lug on the line and fits the smaller or larger calibers.
I do have GAP but used a pressure bleeder I prefer this method.
I bought Merle discs from Ebay for about £85 and pads Febi were about 35.
Callipers came from a 2018 and were in good condition £140 for the pair delivered. I painted them red using VH1 high temp paint and decals came from ebay with clear coat on top
Post #646929 Fri Feb 14 2025 11:16pm
Nick900
https://www.rrsport.co.uk/gallery/albums/u..._0817.jpeg
Post #646930 Fri Feb 14 2025 11:17pm
Gassman
I’ll get ordering the parts. Thanks for the info and tips, will let you know how I get on in a few weeks. Thumbs Up
Post #646933 Sat Feb 15 2025 9:03am
