Home > Technical > Major alignment issue
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi all.
Having had two new upper arms fitted to my sport I was fully aware that the tracking needed doing. But, upon inspection by the garage, there are no lugs or ears with which you would adjust the bolts against to set correctly.
How to rectify this please. Before I ruin my tyres .?
Thanks.
Post #646751 Thu Feb 06 2025 11:21pm
I would think they have been damaged previously by forcing the bolt when being adjusted, might have to get a small piece of steel plate welded onto the bracket to form the lug instead.
Post #646752 Fri Feb 07 2025 12:19am
Toonraider
Good shout that. Cheers
Post #646756 Fri Feb 07 2025 8:38am
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
There is no adjustment to the alignment using bolts on upper control arms, the alignment is done using the lower arm. 2009 Range Rover Sport Supercharged
Post #646836 Mon Feb 10 2025 4:23pm
