![]() | Home > Technical > Major alignment issue |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I would think they have been damaged previously by forcing the bolt when being adjusted, might have to get a small piece of steel plate welded onto the bracket to form the lug instead.
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 104 ![]() ![]() ![]() |
Good shout that. Cheers |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
There is no adjustment to the alignment using bolts on upper control arms, the alignment is done using the lower arm. 2009 Range Rover Sport Supercharged |
