![]() | Home > Maintenance & Modifications > Air struts L320 |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
While changing the height sensors on my 2010 L320 today (what a right royal pain they are to change... thanks JLR) I noticed a split in the bellows on the drivers side rear strut.
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 49 ![]() ![]() ![]() |
Gaffer tape L320 Range Rover Sport 2008
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
The actual airbag is inside the metal tube and the bellows just stops crap getting to the tube alongside the moving airbag. So long as it's clean in there and you can stop anything getting in (gorilla/duck tape short term fix?), then it should be ok.
