RallyeSport
Heater blowing luke warm air. | |
Hello,
2010 Range Rover Autobiography Sport TDV8.
I need to get my head round what’s happening, but will explain here the best I can to start off with……
I programmed timed climate this evening 30 mins before leaving work, the temperature outside was 3/4 degrees C. The FBH works fine with no vapour or smoke at all, you can hear it quietly roaring away and the cabin is just about warmish and all the windows are demisted, so in my eyes it’s doing its job, the AC light flashes orange as normal.
I start the car and drive off, but halfway home (5 miles) the temp gauge is halfway (operating temp) as expected/normal, but the blown air set at 19c is blowing luke warm air only, if you crank it up to 28c the blown air does get warmer, but not hot as you would expect, it stays at this lukewarm warm air temp at 19c all the way home having covered 10 miles.
On the way to work though, early afternoon today (and most days), the temp still at 19c, the blown air temp is quite hot with ambient being 7 outside. I don’t have the timed climate programmed for leaving for work, as it’s not necessary.
It seems like if I have the timed climate on, it’s causing the blown air to be colder when the FBH has been on. Googling the problem, the L322 full fat RR has a directional valve down near the FBH, which gets stuck (15 mins swap out job to replace) - I can’t find reference to this valve on an L320? If it actually has one at all? Which could be the issue.
If I remember rightly if I don’t have the FBH (timed climate) programmed at night leaving work, I’m sure it blows hot air as normal, it does though seem, that every day (engine warm/cooling/warm cycle that the blown air temperature returns to normal again when travelling to work early afternoon no matter what the temperature is.
I thought of a HVAC reset? Or maybe updating the HVAC control module and paying Gap iid for the privilege to see if that helps maybe.
Can anyone help or have I answered my own question?
Cheers in advance
Dean.
