Home > General (L494) > No Start and No Crank
RRS4ED
Hi everyone, hope you all had a happy Christmas and New Year.
My Rangie died on me today and doesn't want to start.
Bit of background information:
Last week my alternator packed in, had a fault code for mechanical performance for the alternator and battery light on, so ordered a replacement.
I fitted it yesterday, car started up fine, no more battery light and fault code cleared. My diagnostic tool showed 14.5v so thought all fixed.
Took it for a test drive this morning round the block and it died, not even half a mile drive.
There is no voltage under the charging points under the bonnet.
I tested the big fuses in the boot area and they all seem to be fine.
I know the ground cables in the wheel arch common on these and i cleaned and put dielectric grease on these in summer as preventative maintenance but haven't checked these yet.
I have got a code in PCM called P0A0F-00 Engine cannot start.
I can hear something click but don't know if its starter or a any relay.
I also know crank is common on these, could check to see if its engine but i think its related to this alternator issue.
The nut holds thick wire behind the alternator was hard to undo as it was tight and i tightened it as hard as i could and thought may be that came off.
I apricate its a long one but if anyone can shed light i would be so grateful.
Post #646262 Sun Jan 12 2025 4:22pm
RRS4ED
I am a bit further on, the main fuse 450A is blown that lives on the right hand side in the boot.
I am not sure why but if i find out i will update here.
Huge shout out to 2RRS who kindly gave me the wiring diagram.
Post #646307 Tue Jan 14 2025 5:56pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Always a pleasure to keep members away from main dealers Bow down
Post #646310 Tue Jan 14 2025 9:12pm
