Home > Faults & Fixes > ACE Yellow Fault
DovFox
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Lux Bonatti Grey
ACE Yellow Fault
Hello,
Just inherited 2015 RRS. Got a yellow ACE warning light on the dash, haven't taken it to the garage yet, but it's a clear leak as there's a puddle under the car and as soon as fill up the tank it empties over night, now given how quickly it empties I assume it's a pretty severe leak or even burst pipe.
I had a look underneath the car and tracked down the leak to a point, but couldn't go any further. I have come across this disconnected pipe... Anyone have a clue what this might be? I'm hoping it's an ace pipe and that is why it's coming out so fast.
The pipe is underneath the engine, nearside (UK).
Thanks in advance 👍
Post #646259 Sun Jan 12 2025 2:53pm
no pics
Post #646260 Sun Jan 12 2025 3:08pm
DovFox
My bad...added 👍
Post #646261 Sun Jan 12 2025 3:11pm
DovFox
RR garage said it's likely to be diesel overflow
Post #646299 Tue Jan 14 2025 2:08pm
DovFox
Took the side under tray off and found the problem, pipe corroded at the front end. Now, RR garage quoted £2k to replace entire front ACE section. The rest of the pipes are completely fine and only need a small section replaced.
There an exact replacement section available on eBay - https://www.ebay.co.uk/itm/267039668354?mk...media=COPY
Has anyone ever done this? Looks fairly straight forward on the books...
Post #646300 Tue Jan 14 2025 2:13pm
I don't think many ppl are working on that age car.
Also this subsection doesn't get much traffic.
You best give it ago!
If you are sure its suitable for your sport model
Post #646301 Tue Jan 14 2025 2:36pm
DovFox
The gent who engineers the pipes has videos on how to do it too, so should be straight forward - will keep people updated. This could potentially save me £1.9k!
Post #646303 Tue Jan 14 2025 5:12pm
Disco_Mikey
£144 for that? Neutral
Post #646304 Tue Jan 14 2025 5:20pm
What’s the price and availability of oem
Post #646305 Tue Jan 14 2025 5:28pm
DovFox
RR said anywhere between £500-600 for either front or rear set of pipes. Would have to be put on a back order, waiting time anywhere between 2-3 months 😳😅
Can get used ones on eBay for roughly the same prices though...
I mean £144 for a tiny pipe seems steep, but given the alternative options I think it's very reasonable. I had a good look at the rest of ACE Pipes and they're all in perfect condition - I don't understand why it's so common for them to rot in that specific area...
Post #646306 Tue Jan 14 2025 5:33pm
Disco_Mikey
It's maybe different for us up here. If the pipes have rotted through there, they're pretty well Censored everywhere else Laughing
Post #646308 Tue Jan 14 2025 6:03pm
DovFox
All fixed. No more leaks. Was straight forward, used pipe cutter to trim to size. The kit came with compression fittings. Had to bleed the system through rear bleed points - just awaiting calibration and should be good to go 👌
[/img]
Post #646436 Wed Jan 22 2025 8:05pm
