Home > General > Remove rear door panel while door is shut
Lexy86
United Kingdom 2008 Range Rover Sport TDV8 HSE Orkney Grey
Hello, i am looking for some advice we have recently purchased a Sport 3.6 V8 2008 model and the rear passenger door wont open, can anyone help with the removal of the internal panel, we have taken the clips and screws out but still cannot remove the panel,
Any help or advice would be greatly appreciated Smile
Post #646135 Tue Jan 07 2025 5:54pm
Farmer Chalk
If it’s like the Discovery then the top edge is held down with clips along the top of the window channel and you have to give the panel a sharp tap upwards to release the spring clips..so lift the panel from the bottom and then bang the panel in an upwards direction..
Be aware though that the panel will only lift up so far as the cable for the door release will stop it lifting off totally until the cable is released.. also the electric window switch wiring will need releasing.
Post #646142 Tue Jan 07 2025 10:09pm
Lexy86
Thank you we will give it a go Smile
Post #646161 Wed Jan 08 2025 12:23pm
Axl
2010 Range Rover Sport TDV8 HSE Adriatic Blue
I had the same issue a few years ago and that worked. It was still a bit of faffing about but got there.
I also remember a V70 bonnet cable snapping from the catch at the bonnet.... that was fun.
Post #646199 Fri Jan 10 2025 9:03am
Lexy86
Thank you
The plan this weekend is to get the panel off and see what the issue is,
Upgrade the Discs, Pads and shoes so busy weekend planned Laughing
Post #646204 Fri Jan 10 2025 10:35am
