Home > General > Remove rear door panel while door is shut |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 538 |
If it’s like the Discovery then the top edge is held down with clips along the top of the window channel and you have to give the panel a sharp tap upwards to release the spring clips..so lift the panel from the bottom and then bang the panel in an upwards direction..
Tue Jan 07 2025 10:09pm |
Lexy86 Member Since: 07 Jan 2025 Location: Bolton Posts: 7 |
Thank you we will give it a go |
Wed Jan 08 2025 12:23pm |
Axl Member Since: 20 Nov 2024 Location: Ayr Posts: 66 |
I had the same issue a few years ago and that worked. It was still a bit of faffing about but got there.
Fri Jan 10 2025 9:03am |
Thank you
Fri Jan 10 2025 10:35am |
