Home > General (L494) > how I cleared these codes with replacing a battery
machine3006
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
My dash board on my RRS 2021 lit up like a charismas tree, engine management light, brakes were rock hard and hard to apply, when I did, with force they would stutter, push back on my foot, vibrating , like a nervous twitch.
I had these faults show on the display
Hill decent control not available
ok to drive with caution Stability control not available
I scanned it got these codes
U01B4-87
U3006-00 Control module input power A
U0046-81Vehicle communication bus C - invalid serial data received
I tried to charge my main battery up as it was dead, it wouldn't hold the charge, got prices from Jlr to replace and thought id change the Aux battery while I was at it
JLR Cost
Main battery £357.52
Aux battery £226.00
got the make from the part numbers, they are Exide 960 AGM main and Exide EK151 AGM Aux
Google search found Tanya battery's
Exide 960 £133,
AUX EK151 £43
Next day delivery £19
I put them in and the disco lights disappeared, brakes work as they should and all fault codes disappeared
Problem Solved.
Hope this helps someone in the future.
Post #645887 Sun Dec 22 2024 11:31am
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Even cheaper on ebay and no delivery charge Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #645892 Mon Dec 23 2024 8:21am
RRT
Did you do a BMS reset?
I changed the battery on my wife's car and my MOT garage told me it should also have the BMS reset which they did for me (they are supposed to charge for it but did it as a goodwill gesture).
I asked about the reasons for doing the reset and he said if you don't reset it, the new battery will be dead within a couple of years because the charging profile will be wrong. No idea if this is garage bs but as he did it foc suspect not? MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #645893 Mon Dec 23 2024 10:27am
aero
Australia 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
Yep Bms reset is definitely recommended, i just replaced mine all together, it was cheaper than going to a workshop
Post #646235 Sat Jan 11 2025 9:28am
