Home > General (L494) > how I cleared these codes with replacing a battery
machine3006
My dash board on my RRS 2021 lit up like a charismas tree, engine management light, brakes were rock hard and hard to apply, when I did, with force they would stutter, push back on my foot, vibrating , like a nervous twitch.
I had these faults show on the display
Hill decent control not available
ok to drive with caution Stability control not available
I scanned it got these codes
U01B4-87
U3006-00 Control module input power A
U0046-81Vehicle communication bus C - invalid serial data received
I tried to charge my main battery up as it was dead, it wouldn't hold the charge, got prices from Jlr to replace and thought id change the Aux battery while I was at it
JLR Cost
Main battery £357.52
Aux battery £226.00
got the make from the part numbers, they are Exide 960 AGM main and Exide EK151 AGM Aux
Google search found Tanya battery's
Exide 960 £133,
AUX EK151 £43
Next day delivery £19
I put them in and the disco lights disappeared, brakes work as they should and all fault codes disappeared
Problem Solved.
Hope this helps someone in the future.
Sun Dec 22 2024 12:31pm
Pistnbroke
Even cheaper on ebay and no delivery chargeAlways listen to old people or when they die you will live on in ignorance.
Mon Dec 23 2024 9:21am
RRT
Did you do a BMS reset?
I changed the battery on my wife's car and my MOT garage told me it should also have the BMS reset which they did for me (they are supposed to charge for it but did it as a goodwill gesture).
I asked about the reasons for doing the reset and he said if you don't reset it, the new battery will be dead within a couple of years because the charging profile will be wrong. No idea if this is garage bs but as he did it foc suspect not?MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Mon Dec 23 2024 11:27am
aero
Yep Bms reset is definitely recommended, i just replaced mine all together, it was cheaper than going to a workshop
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
