Home > Maintenance & Modifications > 2010 5.0L SC Ace Pump bypass
Majistrat
Canada 2010 Range Rover Sport Supercharged Baltic Blue
Hello community,
I own a 2010 RR SC V8 5.0L and i have my ace pump dead on me . I have found countless of good advice on bypassing the pump but it was always for the 4.2 L .
Is anyone have tried and successfully did the bypass on a V8 SC 5.0 L ?
If yes please guide me on achieving the same result as 3000$ CAD is too much for an ace pump even at 1500$ CAD is very expensive.
Thank you in advance
Post #645866 Thu Dec 19 2024 1:36pm
Majistrat
Seeing views but no help.... 2010 RR SC 5.0 L
Post #645868 Thu Dec 19 2024 3:13pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Proberly because no one has done it, friendly place this if any one could help I'm sure they would have. The 5.0 didn't sell in huge numbers in the UK so not a big pool to gather from. Good luck tho
Post #645870 Thu Dec 19 2024 5:28pm
jimbg
Probaly get more of a response on the USA site? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #645871 Thu Dec 19 2024 6:43pm
I can't remember for sure, but for some reason I didn't think the 5.0L naturally aspirated sport ever had the ACE/Dynamic Response system fitted or only as a option if it did, if so you may be able to use the belt etc. of the n/a engine to bypass the pump although l'm not sure what else you may need, but if you could locate a complete 5.0L n/a vehicle in a breakers yard you might get all the parts you may need as I believe the roll bars are a different diameter as well, something like 32mm as opposed to 36mm on the s/c vehicles. No totally sure on any of it though, but only a idea and suggestion.
Looking at some drawings, on the 5.0L N/A engine the pump is replaced by a idler, mounting bracket and uses a different length belt as well.
These numbers may well have been superseded by now though.
Idler LR010689
Mounting Bracket LR012980
Belt LR011345
Post #645875 Thu Dec 19 2024 8:39pm
