Home > Maintenance & Modifications > 2010 5.0L SC Ace Pump bypass |
Majistrat Member Since: 19 Dec 2024 Location: Montreal Posts: 3 |
Seeing views but no help.... 2010 RR SC 5.0 L |
Thu Dec 19 2024 3:13pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Proberly because no one has done it, friendly place this if any one could help I'm sure they would have. The 5.0 didn't sell in huge numbers in the UK so not a big pool to gather from. Good luck tho |
Thu Dec 19 2024 5:28pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1841 |
Probaly get more of a response on the USA site? 2023 P440e SE Dynamic on order -cancelled
Thu Dec 19 2024 6:43pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
I can't remember for sure, but for some reason I didn't think the 5.0L naturally aspirated sport ever had the ACE/Dynamic Response system fitted or only as a option if it did, if so you may be able to use the belt etc. of the n/a engine to bypass the pump although l'm not sure what else you may need, but if you could locate a complete 5.0L n/a vehicle in a breakers yard you might get all the parts you may need as I believe the roll bars are a different diameter as well, something like 32mm as opposed to 36mm on the s/c vehicles. No totally sure on any of it though, but only a idea and suggestion.
Thu Dec 19 2024 8:39pm |
