Home > Maintenance & Modifications > L320 2010 Front Brake Carrier Bolts
toeuk1
Hi, I need to change the front discs on my TDV8 2010 Sport.
Does anybody know the correct size E Torx socket required to remove the carrier bolts please?
Cheers,
Tony.
Post #644776 Thu Oct 17 2024 11:56pm
Are you sure they are Torx headed and not just 21mm Bi-Hex? they are done up F/T as well 270/280Nm
Post #644777 Fri Oct 18 2024 3:07am
Oldandconfused
This may help if you want to work on your discs/pads. It's from the Disco3 site, but same as L320.
https://media.disco3.co.uk/gallery/albums/...1.4sml.pdf
Post #644779 Fri Oct 18 2024 12:34pm
toeuk1
Thanks for the replies. Yes, my mistake, I need a 12 point 21mm socket.
Thanks again.
Cheers.
Post #644780 Fri Oct 18 2024 2:08pm
